Author Topic: Version Control and Nested Packages  (Read 3478 times)
TrtnJohn
« on: June 30, 2004, 05:17:09 pm »
If I am using nested packages can I place each level under seperate version control?  (Or only the lowest levels?)  What happens with the child packages if I checkout a parent?  There doesn't seem to be any recursive checkout going on when I try and set this up.  Can anyone help me understand the best way to take a project with multiple levels of packages and work with version control?  Thanks.
ms_butterfly
  • When you think it's bad, relax: it can get worse
Re: Version Control and Nested Packages
« Reply #1 on: July 21, 2004, 02:40:30 am »
Hallo!
If you have multiple levels of packages, it is possible to add each level to the SCC tool. But, to add a child package, it is necessary that the parent package is checked-out by you.
When you check-in a parent folder, and the child folder is not checked-out, you can't work in the child package until you check it out.
If a child package is checked-out, and you want to check-out the parent package, you must firstly check-in the child, otherwise you can loose the changes since the last time you have checked-in the child package.
I hope I have helped you a little bit.
Have a nice day!
