Author Topic: Importing interfaces of a COM IDL/Typelib  (Read 3707 times)
Tilman
« on: June 18, 2004, 04:21:54 am »
is it possible to import interface-defintions from (Microsoft) COM IDLs or typelibs?
This would be VERY valuable to make documentations of COM-serves.
Thanks in advance,
Tilman
Tilman
Re: Importing interfaces of a COM IDL/Typelib
« Reply #1 on: June 21, 2004, 04:43:42 am »
 :( Unforunately I'm the only one who needs to document (MS) COM-Servers.
But I helped myself and used a library from www.codeguru.com (lib2usr or so) to convert the typelib into a C#-File. This can be read in by EA. :-)
TrtnJohn
« Reply #2 on: June 24, 2004, 08:33:59 am »
I have the same issue.  But I could not find the utility you mention at codeguru.  Any possibility of a direct link???
Pretty please...
« Last Edit: June 24, 2004, 08:34:28 am by TrtnJohn »
Tilman
« Reply #3 on: July 22, 2004, 08:00:10 am »
The link is
http://www.codeguru.com/Cpp/COM-Tech/atl/atl/article.php/c57/
Here is the code to 'convert' a TLB into a C# interface declaration which can be read in by EA:
// Tlb2Cs.cpp : Defines the entry point for the console application.
#include "stdafx.h"
void WriteLine (HANDLE fh, LPCTSTR szLine)
 size_t nLen = _tcslen (szLine);
 DWORD dwBytesWritten;
 ::WriteFile (fh, szLine, (DWORD) nLen, &dwBytesWritten, NULL);
int _tmain(int argc, _TCHAR* argv[])
 HRESULT hr = CoInitialize(NULL);
 HANDLE fh = INVALID_HANDLE_VALUE;
 TCHAR szLine[2000];
 try
   if (argc != 4)
     _tprintf (_T("Usage: Tlb2Cs <Typelib> <Namespace> <Outputfile>\n"));
     return 1;
   // read in typelib
   Typelib::ILib2MePtr spLib (__uuidof (Typelib::Lib2Me));
   spLib->Load (argv[1]);
   // create outputfile
   fh = ::CreateFile(argv[3], GENERIC_WRITE, 0, NULL, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, NULL);
   if (fh == INVALID_HANDLE_VALUE)
     _tprintf (_T("Can't create output file\n"));
     return 1;
   // namespace
   _stprintf (szLine, _T("namespace %s\n{\n"), argv[2]);
   WriteLine (fh, szLine);
   int nClass = 0;
   while (true)
     Typelib::ILClassPtr spClass = spLib->GetClass (nClass++);
     if (spClass == NULL)
       break;
     switch (spClass->Kind)
     case TKIND_ENUM:
       _stprintf (szLine, _T("  enum %s\n  {\n"), (LPCTSTR) spClass->Name);
       for (int t1=0; t1<spClass->CountVariable; t1++)
         Typelib::ILVariablePtr spVar = spClass->GetVariable (t1);
         _stprintf (szLine, _T("    %s,\n"), (LPCTSTR) spVar->Name);
       _stprintf (szLine, _T("  }\n\n"));
       break;
     case TKIND_DISPATCH:
       _stprintf (szLine, _T("  public interface %s\n  {\n"), (LPCTSTR) spClass->Name);
       // attributes
       for (int t2 = 0; t2 < spClass->CountVariable; t2++)
         Typelib::ILVariablePtr spVar = spClass->GetVariable(t2);
         _stprintf (szLine, _T("%s %s\n"), (LPCTSTR) spVar->Type, (LPCTSTR) spVar->Name);
       // methods
       for (int t3=7; t3<spClass->CountFunction; t3++)
         Typelib::ILFunctionPtr spFunction = spClass->GetFunction (t3);
         switch (spFunction->InvokeKind)
         // Function
         case 1:
             _stprintf (szLine, _T("    %s %s ("), (LPCTSTR) spFunction->GetReturnType(), (LPCTSTR) spFunction->GetName());
             int nParCount = spFunction->ParameterCount;
             for (int t4=0; t4<nParCount; t4++)
               Typelib::ILParameterPtr spPar = spFunction->GetParameter (t4);
               TCHAR szParameter[400];
               _stprintf (szParameter, _T("%s %s"), (LPCTSTR) spPar->Type, (LPCTSTR) spPar->Name);
               _tcscat (szLine, szParameter);
               if (t4 < nParCount-1)
                 _tcscat (szLine, _T(", "));
             _tcscat (szLine, _T(");\n"));
           break;
         // getter
         case 2:
             _stprintf (szLine, _T("    %s %s { get; }\n"), (LPCTSTR) spFunction->GetReturnType(), (LPCTSTR) spFunction->GetName());
           break;
         // setter
         case 4:
             _stprintf (szLine, _T("    %s %s { set; }\n"), (LPCTSTR) spFunction->GetReturnType(), (LPCTSTR) spFunction->GetName());
           break;
         default:
           // set a breakpoint here!
           _stprintf (szLine, _T("    // %s %s // Unkown !!!"), (LPCTSTR) spFunction->GetReturnType(), (LPCTSTR) spFunction->GetName());
           break;
       _stprintf (szLine, _T("  };\n\n"));
       break;
     case TKIND_COCLASS:
       break;
   // namespace
   _stprintf (szLine, _T("}\n\n"));
 catch (_com_error & e)
   hr = e.Error();
 catch (...)
   hr = E_FAIL;
 if (fh != INVALID_HANDLE_VALUE)
   CloseHandle (fh);
 return 0;
