Author Topic: Access to linked class in code generation template  (Read 3777 times)
Q-Man
« on: June 06, 2007, 05:30:08 am »
I want to edit the "class body" template (ActionScript code generation). There i need to get the Names of the class that is linked with an association.
How can I manage that? The "linkAttName" macro is not visible from there.
Thanx for help.
Re: Access to linked class in code generation temp
« Reply #1 on: June 07, 2007, 12:58:01 pm »
If you need that (apart from listing the attributes) then you'll need to create a custom template (either linked attribute or connector) and list over that from the class body template.
