Author Topic: Showing Sterotype on Actor in Business Process Dia  (Read 2704 times)
Jeff Odell
« on: August 02, 2004, 07:48:19 am »
I've put a stereotype on an Actor but it does not show up in the diagram.  I have not selected the Hide Sterotype on Features check box in the Diagram properties.  Is there a way to get this to show?
Thanks - Jeff Odell
« Last Edit: August 02, 2004, 07:48:43 am by odelljl »
Re: Showing Sterotype on Actor in Business Process
« Reply #1 on: August 05, 2004, 08:44:53 am »
Jeff,
I presume you used an own stereotype.  These initially do not show up for actors. If you want to have a special icon, you need to set it up using Configuration/UML/Stereotypes.
