Author Topic: Removing unused objects  (Read 5955 times)
wmac
« on: August 15, 2004, 06:43:00 am »
I have created and removed many different objects and now that my digrams are finalized I need to remove those objects which are not used on any diagram.
Is it possible to remove those unused objects ? (at least in each separate package) ?
These are hundreds of objects and finding and removing of those objects is a big project itself. (I should have removed objects from Object Tree in Project View pane to avoid this but is there anything I can do?
Mac
Bruno.Cossi
Re: Removing unused objects
« Reply #1 on: August 15, 2004, 07:16:25 am »
you can use the search functionality (Edit > Find) to find all of your unused objects. In the Find window, check the option "Find Orphans". This will find all of the unused objects (i.e. objects not placed on any diagram) throughout all your model. You can then select all of them and click on the button "Delete Selected".
Hope this helps!
Bruno
wmac
« Reply #2 on: August 15, 2004, 07:54:31 am »
Bruno
Thank you very much for your help.
This is not the first time you help me. I really appereciate that.
Mac
Bruno.Cossi
« Reply #3 on: August 15, 2004, 09:04:35 am »
Mac,
you're very welcome!
Bruno
