Author Topic: insert related elements generates erorrs  (Read 2800 times)
moses
« on: August 16, 2004, 07:54:58 am »
I have this interesting trouble when working against a repository on MSSQL :
When I try to insert related elemnts (right click on any element in a diagram), it will yield that there is an error :
ADODB.Field[-2146825267] - i get the message in czech, but is something like : "the flag is either BOF or EOF or the actual record was deleted. The operation requires an actual record.". it will insert the elements after all, but I get this warning for each of them, so it is quite annoying ... The fun is that we just agreed all of us will start using the database repository ...
We have tested on 2 comps, and I have the newest  build.
Any idea ?
thanks a lot, regards, Moses
btw : is there a specialized bugs forum ?
« Last Edit: August 16, 2004, 07:56:16 am by mojzis »
TrtnJohn
Re: insert related elements generates erorrs
« Reply #1 on: August 16, 2004, 11:47:01 am »
I am not sure what your problem is.  But if you are a registerd user you can submit a bug report here:
http://www.sparxsystems.com.au/registered/reg_bug_report.htm
