Author Topic: Interbase - Triggers and Stored procedures  (Read 2272 times)
ninjashark
« on: September 09, 2004, 04:14:06 am »
I have created some triggers and stored procedures in a interbase database table in EA 4.10732 and I am now trying to generate a sql script.
Unfortunately when the script is generated the triggers and stored procedures are not created using the correct syntax so it can run using interbase tools without generating errors.
Is there a interbase DDL configuration file I can edit so I change  the syntax that is generated.
If not is there likely to be a fix soon!!!
