Author Topic: Different colors of a specific class in diagrams  (Read 3047 times)
mamomuc
« on: August 23, 2004, 01:59:36 am »
Hi there,
I have drawn a specific class in a diagram with the standard color. When I'm trying to use the same class in a different diagram with a different color, the class in the first diagram changes its color as well.
Is there a way to use different colors for one class in differnet diagrams (for example to show a different state).
Cheers,
Markus
Re: Different colors of a specific class in diagra
« Reply #1 on: August 23, 2004, 07:13:04 am »
Just tried that. Works as designed. You can have different colors. I only had this effect with boundaries and notes I copied as link. But classes work fine  ???
mamomuc
« Reply #2 on: September 07, 2004, 02:44:14 am »
Hi Thomas,
I have used the adjust appearance dialog, which gives the described effect. With the format toolbox it works well.
But as described in an new post, I have the problem with connectors. Here the format tollbox is not accessible.
Have you, or someone else,  any idea how to change  the color of connectors without influencing the color on the other diagrams?
Cheers
Markus
« Reply #3 on: September 10, 2004, 04:08:38 am »
Unlike classes, associations seem to have stored their appearance globally and not related to the diagram :-/
