Author Topic: How to connect a method/operation with its diagram  (Read 2977 times)
HaveABeer
« on: September 09, 2004, 06:49:21 am »
How to connect a method/operation with a behavioral diagram? Where can I model the implementation of the method/operation?
Best regards
Adam
TrtnJohn
Re: How to connect a method/operation with its dia
« Reply #1 on: September 09, 2004, 01:55:00 pm »
I am not sure if this answers your question:
A Method/Operation on a class is used when specifying messages between instances in a sequence diagram.  Make sure when you create a new object instance on a diagram that you drag in an instance from a class specifier from a logical view.  If you do, then the method names from the class specifier will appear when you select the dropdown on the Message Property window.
HaveABeer
« Reply #2 on: September 10, 2004, 03:51:56 am »
There is some misunderstanding here. Sorry.
I'm not asking how to model the fact that I want a method to be called.
What I want to model is the implementation of a method. Ideally I would want to be able to add a sequence/activity diagram to a method (a diagram below a method in the project tree) but I know it's not possible in EA.
Any other solution?
mbc
  • Embedded software developer
« Reply #3 on: September 10, 2004, 04:50:56 am »
My solution would be to add the diagram under the class and give it the same name as the operation. I agree that it would be ideal to be able to add a diagram as a child of an operation in the project tree.
Mikkel
