Author Topic: Code Generation : Generating file pairs  (Read 3306 times)
doctor_uv
« on: June 15, 2007, 07:02:31 am »
I am working on generating a file pair for a website out of EA for a generic CRUD application from a domain model.
I created an ASP.NET language which works fine. :-)
However, there seem to be no way to trigger the generation of the XXXXImpl Macro tree. :-(
I worked around by replacing the C++ code generation with my asp.net and code behind class which works but feels odd.
Any suggestion how to do this better?
I found a few odd ends with the code generation by now.
this issue seems to point in the same direction as the missing option to specify a file suffix for a code language..... (another post I found in this forum)
I am already using a number of transformations generating parallel and almost identical trees in the UML using only different setting for the code language.
However, this explodes the UML model unnecessarily. We need a better support for generating different languages from the same package. This seems to be the better approach for a number of applications
(e.g.
asp.net + code behind class
entities + hibernate mappings + dto classes
Dr. UV
Software Architect
Alcatel-Lucent IPTV
Re: Code Generation : Generating file pairs
« Reply #1 on: June 17, 2007, 01:03:28 pm »
Filenames (including implementation files) can be specified in EA 7.0 using CodeOptions in an MDG technology.  See http://www.sparxsystems.com.au/EAUserGuide/index.html?addingcodemodulesinmdgtec.htm.
