Author Topic: Updating on Linux  (Read 3374 times)
mdeggers
  • I love YaBB 1 Gold!
Updating on Linux
« on: July 13, 2004, 02:20:38 pm »
I'm using Enterprise Architect 4.0 on Linux under CrossOver Office 3.0.1.
I wanted to update to 4.1 and thought I could just download the latest zip file to accomplish this.
I backed up my current EA.exe, and then copied the new EA.exe into the appropriate spot:
~/.cxoffice/dotwine/fakewindows/Program Files/Sparx/EA
However, when I went and started EA, nothing happened.  I tried running ea from the command line (~/cxoffice/bin/ea) and got a nasty traceback list.  I can reproduce this and send if needed.
When I moved back to the old version of Enterprise Architect (4.00.729), the dialogue box to register the product popped up.
Fortunately I have my license code backed up to a separate file, so reregistering the program was not difficult.
Is there any way of cleanly updating the Linux version short of doing an uninstall, reinstall, reregister?
Thanks for making a great product, and thanks for getting it to work on Linux.  I wish there was a native port since under Linux / CrossOver Office it's a bit sluggish even on a Dell 8200 with 768 MB, but running on Windows right now is not an option (virus'ed machine).
Thanks in advance - /mde/
johnr
Re: Updating on Linux
« Reply #1 on: July 18, 2004, 05:39:59 pm »
As with any major release of EA, a complete install is necessary i.e. from 3.60 to version 4.0 or version 4.0 to 4.1. With Linux at the moment a complete reinstall of EA is required. At a later stage we are planning to introduce a patch system similar to windows versions.
With Windows, if you do a full install you will be able to use the update patch files to upgrade builds until the next major release of EA.
« Last Edit: July 18, 2004, 10:16:15 pm by johnr »
reggiehg
« Reply #2 on: September 25, 2004, 03:11:39 am »
Hi!
We are considering using Enterprise Architect, and the only reason we are hesitating is the requirement of using CrossOver. Is that a reasonable consideration, apart from the speed issue you mentioned? I mean is it reliable?
Reggie Guevara
