Author Topic: copying dependency between diagrams - visible only  (Read 3014 times)
mamomuc
« on: September 30, 2004, 09:29:15 am »
Hi there,
I copy in diagram a a dependency to diagram b (with the related classes). In diagram b no dependency is visible (the classes are visible). If I check the visbility in diagram a, I can set the visibility of the dependency in diagram b. But there is no change in diagram b.
Is there a way to make the dependency in diagram b visible?
Cheers
Markus
Re: copying dependency between diagrams - visible
« Reply #1 on: September 30, 2004, 11:15:26 am »
Locate it in the Relations frame (by selecting one of the associated elements). Right click there and click Show Relation.
mamomuc
« Reply #2 on: October 01, 2004, 12:28:53 am »
Hi Thomas,
I tried it already. If I right click on the relation within the relation frame no entry show relation is visible.
Only the entries for the associated elements and delete connector is contained.
Markus
« Reply #3 on: October 01, 2004, 03:42:57 am »
I tried with several associations - all worked fine. Maybe an EA version issue (I use the latest).
