Author Topic: Avoid comments - Help needed  (Read 4387 times)
rescobar
  • Viva Bolivia
« on: October 06, 2004, 08:15:55 am »
Hi, muchachos!
I don't like the comments generated by the forward eng. procedure. I would like to avoid them. How could I specify not to generate those comments? Or maybe to change them?
I tried "Code Generation Templates" erasing "Notes" but comments are generated anyway.
Thanks in advance for your kind help
Ramiro
Sergio Escobar
Bruno.Cossi
Re: Avoid comments - Help needed
« Reply #1 on: October 06, 2004, 08:33:28 am »
Hola,
I think you are referring to the comments on the file, right? If you look at the code generation template for, for example, C#:
//  %fileName%
//  Implementation of the %elemType% %className%
//  Generated by Enterprise Architect
//  Created on:      %eaDateTime%
%if classAuthor != ""%
//  Original author: %classAuthor%
%endIf%
///////////////////////////////////////////////////////////\n
$COMMENT="WARNING: DO NOT MODIFY THIS TEMPLATE BELOW THIS POINT"
\n\n
%ImportSection%
%list="Namespace" @separator="\n\n"%
Just remove this:
//  %fileName%
%endIf%
That will stop generating the comments.
Hope this helps!
Bruno
rescobar
  • Viva Bolivia
« Reply #2 on: October 06, 2004, 11:01:46 am »
Hi, Bruno. Thanks a lot. It works!
Sergio Escobar
Bruno.Cossi
« Reply #3 on: October 06, 2004, 12:27:05 pm »
You're welcome!
