Author Topic: Database Corruption  (Read 3634 times)
adamb
Database Corruption
« on: October 06, 2004, 08:59:42 am »
I have user utilizing EA 3.60 Build 653 and 658. Does this cause any inconsistencies?
I have several users accessing one database. Occassionally this database becomes corrupt. In order to repair it we have to open the database in Access and choose a repair option.
I do have users that are using Access 2000 and others that use Access 2002. Is this a problem?
My users suspect that this condition occurs when a user's particular instance of EA crashes.
I am trying to diagnose what could be causing the problem. I do not see anything reported on the server logs. The lock file is not too helpful in indicating what is happening. What are some troubhleshooting steps that I can process through?
Re: Database Corruption
« Reply #1 on: October 06, 2004, 02:24:22 pm »
(Just a preliminary sentence: start thinking about upgrading!)
Okay, there should not be an issue with accessing the same DB with these builds (AFAIK!). A problem could be that some of your "native" Access users are working with the wrong Jet machine. To repair the database I would recommend to use EAs buildt-in repair function (which is obviously the same as Access') so you're on the save side. Additionally you should use the data integrity check offered by EA!
