Author Topic: Setting order of elements in Project View  (Read 2652 times)
DaveMathews
« on: October 18, 2004, 11:05:14 am »
Hi, I used the up and down arrows to set the order of elements that appear under a screen element in the project view. I save, exit project, retun. The order has not been saved.
Any suggestions?
Re: Setting order of elements in Project View
« Reply #1 on: October 18, 2004, 12:06:15 pm »
You mean you used the pointing hand symbols, do you? They should work immediately (open the same project in another EA instance and you should see it in the new order).
DaveMathews
« Reply #2 on: October 18, 2004, 01:44:54 pm »
Hi, It seems to work at the package level, but not at the element level. Perhaps I am expecting the wrong behavior?
Here is my PV:
- <<Screen>> Example
    - <<drop down>>To account
    - <<drop down>>From account
    - <<button>>OK
    - <<button>>Cancel
    - <<textbox>>First Name
    - <<textbox>>Last Name
I use the Up icon to arrange the element to the  following:
Here is my PV:
    - <<button>>OK
    - <<button>>Cancel
I right click on the tab for the diagram, then select Save All.
After I close the project and reopen, I'm back with the same order.
<<Screen>> Example
    - <<button>>OK
    - <<button>>Cancel
Some of my screens have 30-40 elements, so it is important to be able to order them in the PV.
Thanks, Dave
« Reply #3 on: October 19, 2004, 02:57:29 am »
Hi Dave,
you are right. It seems EA does not memorize the ordered position. I'd call it a bug and you should report it.
