Author Topic: Appearance  (Read 4054 times)
rescobar
  • Viva Bolivia
Appearance
« on: October 19, 2004, 12:32:51 pm »
Hi, muchachos!
I have changed the appearance of a individual class (backcolor, lines, etc). I am very satisfied with that new appearance. Now I want to apply this appearance to another object. How could I get that? (step-by-step).
I did not found this in help file.
Thanks a lot for your kind help
Ramiro
Sergio Escobar
Re: Appearance
« Reply #1 on: October 19, 2004, 01:58:15 pm »
Was just doing the same sort of work: Select the first element, then all others (ctrl-click).  Now select Element/Appearance/Config default. Click OK. Now they all look alike.
Kevin Brennan
Re: Appearance
« Reply #2 on: October 19, 2004, 02:00:21 pm »
If you want to change all classes, go to Tools -> Options. Click on Standard Colors to change the fill. Click on Objects to change the border thickness.
To do it class by class, right-click on the class and select Appearance -> Copy Appearance to Painter. Click on the class you want to change and click the Paintbrush icon on the Diagram Toolbar. That will copy the appearance to the new class.
Sr. Consultant at blue sands Inc. and Vice President, Body of Knowledge at the IIBA. All opinions are my own.
rescobar
  • Viva Bolivia
Re: Appearance
« Reply #3 on: October 19, 2004, 02:22:06 pm »
It works! Thank you very much you both.
Regards
Ramiro
Sergio Escobar
