Author Topic: Connect to Server Repository fails (ORACLE 9.2)  (Read 8046 times)
catalina
« on: October 22, 2004, 05:19:13 am »
I am testing Enterprise Architect (Corporate edition). Probably we want to buy it for development in the company I work for (if we can get the DB connection work :)).
Unfortunately, after installing the official ORACLE ODBC driver (on a Windows XP machine) following happens:
1. After clicking "Connect to Server Repository..." I get the Data Link Properties window where I select "ORACLE  Provider for OLE DB".
2. Then in the Connection Tab I entered in Data Source a valid name (a name found in the tnsnames.ora file). After providing my user name and password I clicked "Test Connection" here I get: "Test connection succeded".
3. I click on OK in the Data Link Properties window.
4. I get a new Window Connection Name & Type. I entered a name and click then OK.
5. An Enter Password window appears, I write there the password to access the database again (already given in step 2.) and then click OK.
6. A window with title "EA" appears with the following message: "OraOLEDB [-2147217865] ORA-00942: table or view does not exist" and an OK button.
7. After clicking OK I get a new window with title "EA" and the following message "Enterprise Architect has experienced a network error and will close down"
8. I can only click on OK, EA is closed automatically.
I repeated the procedure with two different ORACLE instances with the same results.
Does anybody have a clue why the connection isn't performed? EA wants to access a table which he doesn't finds, which table is that?
Thanks in advance for your help.
Bruno.Cossi
Re: Connect to Server Repository fails (ORACLE 9.2
« Reply #1 on: October 22, 2004, 05:52:55 am »
in order to connect to a DBMS-based repository, you have to create the repository first, i.e. create all of the tables required. The SQL script for creation of the repository is available for download on SparxSystems website, but only after you purchase Enterprise Architect. Also note that the Desktop and Enterprise edition of EA do not allow connection to a DB repository, only the Corporate one.
Now functionally, there is no difference between using an Oracle-based repository or an EAP file. In fact the EAP file is nothing else but an MS Access database (try opening it in MS Access and see all the tables inside). For evaluation purposes, using the EAP file should be enough.
Hope this helps!
Bruno
