Author Topic: Hiding tags after reverse engineering  (Read 5149 times)
iselmo
« on: October 24, 2004, 06:01:18 am »
Reverse engineering creates tags from properties of Delphi source code. How can I hide them in class diagrams? (hiding other class members is working...)
Thanks, if anyone can help...
dlundy
Re: Hiding tags after reverse engineering
« Reply #1 on: October 24, 2004, 02:43:34 pm »
One mechanism for this:
Double click on the Diagram to bring up the Diagram Properties dialog. Find the Show Tags option button and deselect it. That should do it.
Sometimes you have to refresh the diagram or move away from it and come back to ensure this works.
Dan Lundy
iselmo
« Reply #2 on: October 25, 2004, 01:30:16 am »
Thank you, Dan, but it doesn't work. The diagram's Show Tags option does not affect - and I did not find any public option neither in general tools, nor in diagram options to control this behaviour.
(I have EA 4.1)
dlundy
« Reply #3 on: October 25, 2004, 11:43:56 am »
Hmm. Okay. Try this.
Select the class. Right-click to bring up its context menu. Select the option: Element Features then Specify Feature Visibility...
In the subsequent dialog, in the Show Element Compartments: turn off Tags and the Inherited Tags option boxes. Select OK. That should do it.
Dan Lundy
