Author Topic: How to set the defaults for elements?  (Read 3786 times)
Gabor
« on: October 24, 2004, 01:45:37 pm »
I want to set the default element's appearance (for the element's size and color), but on doesn't work as written in help.
I created a package and named it template. Put the elements into the diagram in this folder, sized it, and set color. Then I choosed the Project/Set Element Template Package, and browsed to the Template folder. Despite this, when I created a new element somewhere, the element doesn't shows the appearence that I set in the template package.
What have I do?
Thanx, Gabor
Re: How to set the defaults for elements?
« Reply #1 on: October 25, 2004, 02:59:07 am »
not that I really know, but it should be stereotyped, not named template.
Gabor
« Reply #2 on: October 26, 2004, 01:32:01 pm »
Can You explain, how to do that?
Thanx
Gabor
« Reply #3 on: October 26, 2004, 03:15:32 pm »
There is an attribute "stereotype" also for packages (open the properties). Then type "template" in this field and try again.
« Last Edit: October 26, 2004, 03:15:56 pm by thomaskilian »
Gabor
« Reply #4 on: October 27, 2004, 06:31:12 am »
Thank You,
I tried to "stereotype" the folder as template, but it doesn't solve the problem.
When I add new issue, on doesn't reflect the formatting of the issue in the template folder. Despite, that I set the folder as Element template package in the project menu.
« Reply #5 on: October 27, 2004, 08:13:01 am »
Just tried it for curiosity. Obviously it does not work as described in the help file. Probably you should send a bug request  :-/
Addendum: For other elements it seems to work (like screen),  but not for requirements and issues.
« Last Edit: October 27, 2004, 08:16:07 am by thomaskilian »
