Author Topic: EAExample - Server instance attribute settings ?  (Read 3398 times)
mikewhit
  • Accessing ....
« on: October 28, 2004, 02:04:36 am »
There's probably a simple answer, but in Messenger / Model Views / Deployment Model / Office Deployment Models / Seattle Office / Servers / SE0001 / , where are the values of the fields, e.g. "Disk Controller = RAID 1", "RAM = 2 x 512MB" set ?
I can see that the fields are attributes of the classifier HP Proliant DL360, but nowhere can I find the editable fields relating to the actual values for SE0001.
Re: EAExample - Server instance attribute settings
« Reply #1 on: October 28, 2004, 04:37:10 am »
Use the Run State from the context menu.
mikewhit
  • Accessing ....
« Reply #2 on: October 28, 2004, 05:59:11 am »
Thanks, I would never have come across that unless I'd printed out the Help file and read it page-by-page !
[Help page title 'Run-time State', or EAUserGuide.pdf 4.2.1.31.2]
Can you get this to be printed out as text in a 'Documentation' report file - there doesn't seem to be any box to tick which will do it, it only appears in the diagram graphic.
« Last Edit: October 28, 2004, 06:05:30 am by mikewhit »
