Author Topic: Adding StringList tags to Stereotypes  (Read 2965 times)
RedCloud
« on: October 27, 2004, 06:27:13 am »
is it possible to add a StringList tag to a Stereotype and to do this in a way that the StringList (after dropping my stereotyped 'object' in a diagram) is editable?
(I'm a bloody newbie in dealing with profiles...  :-[ )
Thanks for replies  ???  :)
Re: Adding StringList tags to Stereotypes
« Reply #1 on: October 27, 2004, 08:01:02 am »
use Configuration/UML/Stereotypes. You can assign any stereotype to appear in any element.
RedCloud
« Reply #2 on: October 29, 2004, 02:01:05 am »
Hi thomas,
my problem is not, to assign a StringList value to a tag, it's to edit the value like a StringList.
The scope is, to be able, to edit the value of a tag in 'Class properties'--> 'Tags'-->'Value' as a StringList (with a multiplicity of Strings, not only one...)
The 'multiplicity of strings' would be the value.
Is there any possibility?
« Reply #3 on: October 29, 2004, 03:44:03 am »
Zapped my previous nonsense.
Refer to section "Predefined Tagged Value Types" in the help. EA is full of treasures  :)
« Last Edit: November 02, 2004, 07:24:16 am by thomaskilian »
