Author Topic: Package Control XML filenames  (Read 3758 times)
danch
  • I love YaBB 1 Gold!
« on: October 28, 2004, 08:57:52 am »
I'm trying to split a model into a set of controlled packages for parallel development. It seems like the fully qualified path of the file is kept within the file itself:
<UML:TaggedValue tag="xmlpath" value="C:\Documents and Settings\danch\My Documents\work\clients\WI\ETF\prototype\model\Prototype Use Case Model.xml"/>
This won't work unless all modellers use the same directory structure, which is very limiting, to say the least. Is there any workaround for this?
mikewhit
  • Accessing ....
Re: Package Control XML filenames
« Reply #1 on: October 29, 2004, 02:35:24 am »
Other people would also like this issue looked at :
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.cgi?board=suggestions;action=display;num=1098457218
[Relative file path]
akos
« Reply #2 on: November 01, 2004, 08:04:08 am »
Configuration / Local Paths / XMI
For details, see the help.
danch
« Reply #3 on: November 03, 2004, 07:45:36 am »
Ah, there it is! Thank you, akos.
