Author Topic: Code Templates Not Accepting Overrides  (Read 4634 times)
ajaxx
« on: November 08, 2004, 01:35:50 pm »
Hey, I've tried to figure this one out, but its really beginning to bug me.  I'm using build 738 and I'm trying to override the stereotype for Class Declaration (I'm building a typedef stereotype to address our need for them).  I click Add New Stereotype Override, it pulls up the dialog with two blank comboboxes, I pull down the first one to "typedef" and leave the second blank (I've tried variations doesn't help).  I then press okay, it accepts it and then does nothing.  No error, no new override.
Has anyone else run into this problem or is this a bug?
Re: Code Templates Not Accepting Overrides
« Reply #1 on: November 08, 2004, 02:47:54 pm »
??? That's odd.  It works for me (regardless of the version or repository type)
When I do it there is a new entry in the Stereotype Overrides list with Class=typedef and Modifier=Yes.  That template is selected and the template itself is the same as the original (unmodified) template.
I hope you can find the problem.
Simon
ajaxx
« Reply #2 on: November 09, 2004, 08:55:26 am »
Yes, its quite odd.  As a follow up, I've tried the following variations (and you'll find the results are just plain wierd).
Alright, I had a stereotype for "typedef".  I added an override for Class Body, but could not add one for Class Declaration.  So I created a new stereotype "alias".  I was able to add an override to Class Declaration for alias, but I could not add one for Class Body.
So, I removed all of the overrides I had added.  And reverted to the default templates.  Went to Class Body, added an alias override and made NO changes.  Then I went to class Declaration and added an alias override and it took as well.  So now I have what I wanted, and I'm not entirely sure why it took in the final case.
I hope this helps, if I can give anymore feedback that would help people looking at this, let me know.
