Author Topic: Annotations in XSD Generation: Problem  (Read 3273 times)
Christian.Hinken
« on: November 05, 2006, 10:00:30 am »
Hello there,
when generating the XSD element for the reference another Element, EA creates an inner ComplexType. Example:
<xs:element name="...">
<xs:complexType>
<xs:sequence>
<xs:element ref="..." minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
<xs:annotation>
<xs:documentation>...</xs:documentation>
</xs:annotation>
</xs:element>
The annotation-element is generated at the wrong place: it should be generated inside the element with the reference. At the current position, it creates an invalid xsd.
Can anyone help me with this problem?
Thanks in advance,
      Christian.
Egbert
Re: Annotations in XSD Generation: Problem
« Reply #1 on: June 26, 2007, 07:41:54 pm »
Hi Christian,
I saw your question to be relevant to problems we experience.
We are building a reference model in EA and we struggle to generate the right XSD for the model.  We would like to import the XSD model into a tool like Altova Mapforce to do mapping between our reference model and various other system meta models.
We found that Altova ask for a "root element" and if you select any of the classes (as a root element) it only import the XSD for the root and his directly associated classes.  The rest of the model is ignored.
I don't know much about namespaces but could this be the problem?
Many Thanks,
Egbert
