Author Topic: MDG Problem?  (Read 3112 times)
rescobar
  • Viva Bolivia
MDG Problem?
« on: November 17, 2004, 11:06:21 am »
Hola muchachos!
I am using MDG. When I use Generate Code (forward eng) from within normal ea right-click menu, the code generated, if the class implements an interface, makes the following code (just an example):
Public Function RolesDelUsuario(ByVal Usuario As IUsuario) As IRoles Implements IUsuario.RolesDelUsuarioImplements IUsuario.RolesDelUsuario
     RolesDelUsuario = Nothing
   End Function
Note that Implements IUsuario.RolesDelUsuario is twice in the method.
When MDG is used with the Add-in, there is no problem, but I think that MDG should not disturb ea normal procedures, ins't it?
Is there somebady with the same problem?
Thanks for your help
Sergio Escobar
