Author Topic: XMI Export/Import with German Character set fails  (Read 4258 times)
chrisHauert
« on: November 22, 2004, 08:20:39 am »
Hi there
I use a EA 4.1 739 unicode version. I try to export a model containing german characters (umlaute ä, ö, ü). The export works, but the xmi file can't be shown.
It can't be imported unless the characters are replaced in the xmi-File, so I loose the german spelling.
Can somebody give me a hint, please?
Cheers, Christoph
Re: XMI Export/Import with German Character set fa
« Reply #1 on: November 22, 2004, 11:13:13 am »
Use the editor an replace the characters manually by the appropriate "&"-notation?
chrisHauert
« Reply #2 on: November 23, 2004, 01:56:04 am »
Hi Thomas
Thanks for the tipp. Unfortunately it doesn't work that way because xml considers &... as a reference to an entity. I added the encoding attribute as it used to be in ea 3.60 with "<?xml version="1.0" encoding="windows-1252" ?> " in the xml file. Then the import works. What I can't understand is that I replaced it in the EA.dtd and in the EA_UML.dtd as well, but it's not taken into consideration when creating the xmi-export.
cheers Chris
Cheers, Christoph
« Reply #3 on: November 23, 2004, 03:20:14 am »
It was a flaw not to relegate umlaut with the "Rechtschreibreform"  ;D
Probably you should then ask for a bug correction. Aussies don't need Umlaut and probably will not have testet against these  ;)
