Author Topic: UML Pattern & Sequence Diagram  (Read 2965 times)
fbe
« on: November 23, 2004, 04:23:35 am »
Is it possible to generate a UML Pattern in EA from a sequence diagram? I have a sequence diagram which I want to use as a base. I can create the UML pattern from the diagram and select classes to add/rename etc. but when that is done, all the messages are gone. I would like the messages to stick around also. Any ideas?
mikewhit
  • Accessing ....
Re: UML Pattern & Sequence Diagram
« Reply #1 on: November 23, 2004, 04:47:51 am »
From EA Help:
Patterns are parameterized collaborations - that is they are a group of collaborating objects/classes that can be abstracted from a general set of modeling scenarios
so perhaps only collaborations are saved 'properly' as patterns ...?
Though I would have thought a Pattern should be applicable to any suitably parameterisable model diagram.
I am guessing that the 'dynamic' elements (messages) are lost, in this case.
« Last Edit: November 23, 2004, 04:49:42 am by mikewhit »
