Author Topic: Reverse Engineering from Java  (Read 2700 times)
Rob_Lam
« on: November 29, 2004, 08:30:14 am »
I'm fairly new to this product so...
I'm trying to reverse engineer some java code to display the class diagrams.  I problem I have is that many of the classes were written to define methods as, eg.:
public class ClassName
    int _variable1;
    public int getInfo
                        (int aParam1,
                         int aParam2)
        code...
when I reverse this code,
The method getInfo ( ), gets translated as an attribute in the class diagram.
When I change the method definition to :
    public int getInfo (int aParam1,  int aParam2)
The method gets translated to a method properly in the diagram.
Aside from changing all the classes to this convention (of which there are many classes), is there something else I can do, or am I missing something?
Thanks in advance,
Rob
Re: Reverse Engineering from Java
« Reply #1 on: November 29, 2004, 01:32:31 pm »
I've just fixed the problem, so I'd suggest that you wait until build 741 is released.  I wouldn't expect it to be more than a couple of weeks away.
Simon
