Author Topic: Issue Date  (Read 4570 times)
rescobar
  • Viva Bolivia
Issue Date
« on: November 30, 2004, 05:25:44 am »
Hola muchachos!
Maybe I'm doing something wrog. I can't change the Issue Date. When I change the date the Save button is not enabled. If I change the issue title or comment, the mentioned button is enabled, but date of issue is not changed. Somebody knows why?
The only way to change the issue is to delete it and to create the issue again.
Thanks for your kind help
Regards
Ramiro
Sergio Escobar
Re: Issue Date
« Reply #1 on: November 30, 2004, 08:48:59 am »
I use 4.5. In the System/System Issues tab it works with no problems. Using the Project/Issues menu it does not recognize a change in the date (the Save is enabled when changing, but does actually not save). Seems to be buggy somehow  :-/
rescobar
  • Viva Bolivia
Re: Issue Date
« Reply #2 on: November 30, 2004, 09:58:46 am »
Thank you for your response. I only get Project/Issues. I can't find System/System Issues. I'm using 4.5 build 740. Where could I get System/System Issues?
Rgds
Sergio Escobar
rescobar
  • Viva Bolivia
Re: Issue Date
« Reply #3 on: November 30, 2004, 11:16:37 am »
got it!!
down under, ins't it?
Rgsd
Ramiro
Sergio Escobar
Re: Issue Date
« Reply #4 on: December 01, 2004, 01:20:16 am »
Yeah. I was used to work with the System variant until I uncovered the second view. I've been asking to unite these views in order to reduce duplicate support questions. Also I'd  prefer to have more functionality in one place rather than distributed in two locations. Likely this topic has rather low priority.
