Author Topic: build 741  (Read 6959 times)
j33@1
build 741
« on: December 01, 2004, 07:11:03 am »
Upgraded to build 741 and now I can't move move a package into another package. Using corporate edition with an Oracle backend, user security is set and I am logged in as Admin.
TIA
Re: build 741
« Reply #1 on: December 01, 2004, 07:18:01 am »
Just tried with .EAP - no problem. Maybe you can try also with .EAP file?
j33@1
Re: build 741
« Reply #2 on: December 01, 2004, 07:22:41 am »
Yes, I can do it with a project that is an EAP.
just noticed that I cannot change any properties of any packages either.
j33@1
Re: build 741
« Reply #3 on: December 01, 2004, 07:31:28 am »
This almost looks like a security thing. I verify that I have the proper admin password but everything is like in readonly, except I can add packages or items. Just can't do anything with them after they are inserted into the project. How can I reset the security on a project?
Re: build 741
« Reply #4 on: December 01, 2004, 07:36:51 am »
Same way as you turned it on: enter the security key again.
j33@1
Re: build 741
« Reply #5 on: December 01, 2004, 08:13:30 am »
The enable security menu item is also greyed out and non-selectable.
j33@1
Re: build 741
« Reply #6 on: December 01, 2004, 09:00:23 am »
Ok, so playing around.
I close EA.
I go into the oracle database and change the value column on t_secpolicies from 'Enabled' to 'Disabled'.
Run EA and security is off and I have free reign with the model.
I enable security again, inputting the key and then admin is locked out of everything again.
Does this need to be reported as a registered user bug?
Re: build 741
« Reply #7 on: December 02, 2004, 02:26:25 am »
Likely this is related to the latest release (a real HOT fix)  ;D
mchiuminatto
Re: build 741
« Reply #8 on: December 02, 2004, 06:53:43 am »
Try build 742
Regards.
Marcello
