Author Topic: problem with transfer export import reference data  (Read 3827 times)
doctor_uv
« on: July 05, 2007, 09:04:17 am »
I am trying to move my transformation and codegen templates from one project file to another. However, I get a unique index error when I try to do that with my modified version for the second time and it does not work.
Is this a bug maybe? For the model XMI I can select to ignore GUIDs of the elements - for the reference data this is missing..... :-(
Do I have to manually modify the XML file during the transfer?? Is there a way to delete unused templates? Do I have to get my DBA shirt out and do it in the database?
Question over questions - I seem to have found an area where the workflow is not completely sound....
Any help is greatly appreciated as the current solutions seem very tedious.  ;)
Dr. UV
Software Architect
Alcatel-Lucent IPTV
doctor_uv
Re: problem with transfer export import reference
« Reply #1 on: July 05, 2007, 09:38:02 am »
so the DBA approach works on an oracle based model .....
I can go to the database and
[glb]delete from t_template where templateType like '%_Template';[/glb]
after that the import of the modified templates from the other EA model works! :)
seems very awkward though!
and won't help if you are using EAP files ????
« Last Edit: July 05, 2007, 09:44:41 am by doctor_uv »
Dr. UV
Software Architect
Alcatel-Lucent IPTV
« Reply #2 on: July 05, 2007, 12:31:22 pm »
Why shouldn't that work with EAP files (just curious)?
Btw. %_template does remove every user defined template, doesn't it?
