Author Topic: 3065 while transfering to MSSQL  (Read 6927 times)
Gobo
« on: April 26, 2004, 08:08:19 am »
DAO.Database [3065]
Cant execute select query
I have such error while transfering EAP file to MSSQL 2000. Not at the begining but at about 70% (t_diagrams). I have followed all the instructions (MDAC 2.8, script passed, EAP file checked and valid)
Have anyone any advice??
Gobo
Jeroen_Wyseur
Re: 3065 while transfering to MSSQL
« Reply #1 on: May 07, 2004, 12:49:29 am »
I just found out that you have to initialize the database first with a database script. See the following web page:
http://www.sparxsystems.com.au/EAUserGuide/index.html?createanewsqlserverreposi.htm
The script is only available to registered users so no trail here I think!
Kind Regards,
Jeroen
Gobo
« Reply #2 on: May 09, 2004, 11:41:39 pm »
Thanks Jeroen, but I followed all the instructions. Without mentioned script the trasfer fails at the begining. In my case transfer stops after a while.
Thanks anyway.
Gobo
« Reply #3 on: May 10, 2004, 01:22:59 am »
Not a very good advice, but would it be possible to delete the diagrams and see if you can import the rest? I had a siminar problem with stereotypes.
yryu
« Reply #4 on: December 15, 2004, 10:44:36 pm »
I met the same problem.
It is related stereotypes.
I deleted the locale language stereotypes. I use Korean.
It works fine.
I think it is a EA bug to solve.
« Reply #5 on: December 16, 2004, 12:25:33 am »
I actually do not remeber well (too long ago) but there might have been some fix. However, deleting the appropriate sections, transferring and manually (or XML-based) restauration worked for me.
yryu
« Reply #6 on: December 16, 2004, 03:31:05 am »
I think you don't have to delete the locale language stereotypes.
I think you can change the locale language to English.
Gobo
« Reply #7 on: December 16, 2004, 05:04:02 am »
Hi, I almost forgot this thread...
anyway, I solved this problem and it was my and only my fault!  :)
I imported some classes by Automation Interface and
created diagrams. I set its type as "Class" by mistake. Everything worked fine while it was running local Access Database or MySQL. But MSSQL checks FKs in better way so I change diagram type to "Logical" and that was it. However such situation is strange the problem is solved. (same situation in other EA repository FKs)
By. Be carefull during automation!
« Reply #8 on: December 16, 2004, 05:19:42 am »
Backup? Backup!
