Author Topic: XML Schema generation HowTo  (Read 5758 times)
PeterHeintz
« on: November 03, 2004, 06:00:05 am »
I am fiddling around with the XML-Schema generation and I had very quickly some success to design my schema somehow top down.
On the leaves of my tree I get lost. I don’t know how to model e.g.
<xs:element name="Doc.Title" maxOccurs="unbounded">
<xs:complexType>
 <xs:simpleContent>
  <xs:extension base="xs:string">
   <xs:attribute ref="Language" use="required"/>
   <xs:attribute name="Status" use="required">
   <xs:simpleType>
    <xs:restriction base="xs:NMTOKEN">
     <xs:enumeration value="UnderDevelopment"/>
     <xs:enumeration value="Released"/>
     <xs:enumeration value="Obsolete"/>
     <xs:enumeration value="Replaced"/>
    </xs:restriction>
   </xs:simpleType>
   </xs:attribute>
  </xs:extension>
 </xs:simpleContent>
</xs:complexType>
</xs:element>
or in other words just a node containing a text node and two attributes.
Any help is welcome.
Best regards,
Peter Heintz
xjecht
Re: XML Schema generation HowTo
« Reply #1 on: December 17, 2004, 01:09:02 am »
I have the same problem.  I created complexType, extended from xsd:string a and attribute added. I got this :
<xs:complexType name="objectclass">
<xs:complexContent>
<xs:sequence/>
<xs:attributeGroup ref="objectclass.att"/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
- it is not valid - I need nested simpleContent (insted of complexContent), without empty xs:sequence.
« Last Edit: December 17, 2004, 01:09:58 am by xjecht »
