Author Topic: template functions  (Read 3632 times)
Martin Terreni
  • Sorry, I can't write
template functions
« on: December 09, 2004, 12:10:54 am »
is there a way I can create my won template functions?
I tryed creating it through new templates.
but if I use ,for example, REPLACE twice on the same string to make changes the out put get prinnted twice.
a waor arround would be if I could define when the macro is for output and when for use.
thanks
Recursion definition:
Martin Terreni
Re: template functions
« Reply #1 on: December 09, 2004, 12:18:27 am »
I think I found a way for the workarrond, but i'd still rather to be able to make new template function (maybe as macros).
« Reply #2 on: December 09, 2004, 01:05:57 pm »
Try assigning the result of the REPLACE function to a variable.  It doesn't modify the string it is passed, instead it returns the result.  If you're not assigning to a variable this will mean that it gets printed.
Simon
Martin Terreni
« Reply #3 on: December 18, 2004, 10:33:37 pm »
that's what I found and it works fine.
