Author Topic: bug?  (Read 3548 times)
kalbun
bug?
« on: December 21, 2004, 03:08:44 pm »
using Borland c++builder, I defined a new class as descendant of a VCL class.
I chose not to use automatic generation of constructor, and instead wrote the member myself - it was easier to add the required parameters and the __fastcall clause.
Ok, suppose the constructor was defined in the EA input mask as:
Return type: __fastcall
Virtual flag checked
Then, generated code is:
virtual __fastcall foo( <various parameters> );
So far so good. But when I generate the code the second time I obtained:
virtual __fastcall virtual __fastcall foo (...
and then
virtual __fastcall virtual __fastcall virtual __fastcall foo (...
And so on towards the infinity   ;D
Is it a bug? Or I'm doing something in the wrong way?
Martin Terreni
  • Sorry, I can't write
Re: bug?
« Reply #1 on: December 21, 2004, 11:31:45 pm »
it is not a bug its a feature ;)
it's ment to make sure you check your code.... ;D
Recursion definition:
Re: bug?
« Reply #2 on: December 23, 2004, 01:53:42 pm »
Yes... It's a feature...  ;)
Unfortunately we may need to ... remove that feature.  It's ... causing ... um ... compatibility issues.
Simon  ;D
