Author Topic: C++ code outside curling braces  (Read 4238 times)
kalbun
« on: December 23, 2004, 02:09:55 pm »
Suppose I have a class like this:
class TAmbient : public TTabSheet
If TTabSheet constructor has no parameters, then I don't need to define TAmbient constructor because:
TAmbient* Ambient = new TAmbient
is OK (the compiler automagically generates the ancestor's constructor).
But suppose TTabSheet constructor requires a parameter : in this case I need to write an explicit constructor, which source code is something like:
__fastcall TAmbient::TAmbient(TComponent* AOwner)
: TTabSheet(AOwner)
Now the question : how to do it with EA? If I write code outside the curling braces, it is deleted each time the source code is generated!!
ok, enough for now...
Happy X-Mas and Peace to everyone!!
Re: C++ code outside curling braces
« Reply #1 on: December 23, 2004, 02:23:52 pm »
What you need to do is create a tagged value on your constructor called "initializer".  In the value put TTabSheet(AOwner).
Alternatively put <memo> in the value field so that you can put a much larger amount of initialization data in.
Merry Christmas to you too.
Simon
