Author Topic: Where does EA place the log file  (Read 7501 times)
Karl ONeill
« on: January 05, 2005, 02:09:16 am »
I'm having frequent crashes (about every 1,5 hours or so). It says that a critical error has occured and that EA is creating a log file. However, I cant find the log file. Any idea where this is placed?
Cheers,
Karl O'Neill
Re: Where does EA place the log file
« Reply #1 on: January 05, 2005, 02:21:31 am »
I guess this is produced by Norton. Not of much use AFAIK. Never had EA reporting to crash and write a log. You should check the system error log.
« Last Edit: January 05, 2005, 02:22:44 am by thomaskilian »
Karl ONeill
« Reply #2 on: January 05, 2005, 02:28:20 am »
Cheers, I am running norton but so is everyone else here.So far i know im the only one within the firm with this problem but im loosing quite a bit of work and im having to back track every time to see what has been saved and what has been lost. Anyobody know the specific directory?
« Last Edit: January 05, 2005, 02:29:14 am by KOneill »
Martin Terreni
  • Sorry, I can't write
« Reply #3 on: January 05, 2005, 11:21:00 pm »
As writen before -you better check system log. it will most probably be writen ther wich program exatly was the one that fell.
Any way , fomr my long expirience in supprt (a few years) I can tell you the fact that it works for every eon else and not for you doesnt mean it is not norton (or some other program).
I know it is not very helping, but since it is not an EA message the most important thing would be to check which program message is it.
regards
Recursion definition:
Karl ONeill
« Reply #4 on: January 06, 2005, 12:12:49 am »
Thanks guys, had someone from support look at my pc yesterday. Turns out its not only EA that is playing up so i think it a problem with my laptop.
Cheers,
Karl
