Author Topic: Fork/Join Name Disappears  (Read 3642 times)
Jeff Odell
« on: January 06, 2005, 05:12:20 am »
I m using the Fork/Join construct to identify concurrency in my Activity Diagrams.
By default these objects do not have a name.  In order to tell them apart, I used the Property pane to assign a name in the Name field.
As soon I redisplay the Fork/Join in the diagram, the name appears briefly next to the Fork/Join in the diagram then disappears.  Subsequently the Name property is gone from the Property editor.
Can we have:
1) The ability for the Name property to be persistent; and
2) the option for the name to appear or not in the diagram?
Thanks -
Jeff Odell
Re: Fork/Join Name Disappears
« Reply #1 on: January 06, 2005, 06:43:03 am »
Does not look like this is intended. You should report a bug via the bug report...
Also I don't see a reason why the fork/join does not appear in the project browser (start, choice, etc. do appear).
« Last Edit: January 06, 2005, 06:44:45 am by thomaskilian »
Jeff Odell
« Reply #2 on: January 06, 2005, 08:47:14 am »
I have reported it to Sparx as well.
jlo
Jeff Odell
« Reply #3 on: January 08, 2005, 06:51:07 am »
Reply from tech support indicates this will be fixed in the next build.  Thanks Sparx! :D
