Author Topic: Code Template  (Read 6144 times)
gavinbarton
Code Template
« on: July 11, 2007, 12:30:13 pm »
I have been using the CTF in EA 7 to create code however I have hit a wall with looping and parameters. I would like to create a code template that utilises the parameters defined in an operation.
For example, I have an operation defined as:
public DataSet GetName(string Name, string Address)
   Database db = DatabaseFactory.CreateDatabase();
   DbCommand cmd = db.GetStoredProcCommand("search");
   db.AddInParameter(cmd, "Name", DbType.String, Name);
   db.AddInParameter(cmd, "Address", DbType.String, Address);
   return db.ExecuteDataSet(cmd);
The built in templates produce the following:
   return null;
I can easily add in:
I would like to create a CTF operation template to process the parameters so that for each parameter it adds:
   db.AddInParameter(cmd, %ParamName%, %DBType%, %ParamName%);
The template for the method would be:
public DataSet OperationName(params)
   DbCommand cmd = db.GetStoredProcCommand(%SP_NAME%);
   foreach(param in params)
In the EA guide an example uses %list="Parameter" @separator=", "% to fetch all of the parameters but there appears to be no looping mechanism to loop through each parameter so that I can:
1) Work out the type
2) Grab the name
The second thing that I would like to work out is if there is a way to pass in variables for a particular operation.  For example the operation could have a stored procedure naame associated to it.
Any help with the above would be greatly appreciated.
Gavin
« Last Edit: July 11, 2007, 12:30:40 pm by gavinbarton »
Re: Code Template
« Reply #1 on: July 11, 2007, 12:35:43 pm »
This is the situation that custom templates are for.
http://www.sparxsystems.com.au/EAUserGuide/index.html?customtemplates.htm
Create a template of type parameter called Add.  This creates a template Parameter__Add that you can enter
db.AddInParameter(cmd, %paramName%, %DBType%, %paramName%);
You can then list over that template with
%list="Parameter__Add" @separator="\n" @indent="\t"%
All that's left of that is how you've defined %DBType%.
gavinbarton
Re: Code Template
« Reply #2 on: July 11, 2007, 01:17:25 pm »
Thanks that worked a treat.
Is there anyway in store additional custom properties on an 0peration.  In my example I have a stored procedure name, if I can set it as a custom property then the template can pick it up and included it.
I look at the alias but I dont think this would be suitable.
Thanks for the help
Re: Code Template
« Reply #3 on: July 11, 2007, 01:43:58 pm »
Tagged values is the standard extension mechanism and can be accessed in the code templates with %opTag:"tagName"%.
gavinbarton
Re: Code Template
« Reply #4 on: July 11, 2007, 02:07:40 pm »
thanks again.
