Author Topic: Flow line routing  (Read 2883 times)
jeshaw2
Flow line routing
« on: January 09, 2005, 08:18:35 am »
I'm doing Business Process Modeling.  I have two or more flow lines between two processes, each having a different trigger.
For example:
Two Processes: Hire Employee, Terminate Employee.
Event Triggers: Drop in business volume, Resigned, Could Not Meet Job Requirements, etc.
When I add the second flow line, it overlays the first flow line, so I need to control the line's routing to make each visible.
Is manual routing implemented in the Evaluation version, build 744, of EA?  If so, where is it?
Re: Flow line routing
« Reply #1 on: January 09, 2005, 02:39:48 pm »
Ctrl+LeftMouseClick on the line to add a line point, then LeftMouse to drag it anywhere you like. Repeat as often as you like.
