Author Topic: Version 3.10 (Build 465) released  (Read 53723 times)
sparks
« on: February 18, 2002, 03:02:32 am »
On the 18-Feb-2002
Enteprise Architect Version 3.10
A minor release (build 465) was uploaded to the website.
changes:
Added ability to define additional Project Root Nodes (multiple projects in Tree Browser)
Added ability to define keyword substitution in RTF documents ('Adjust Language' button on RTF dialog)
Abstract classes now denoted with italic name, rather than dotted border (UML 1.4 convention)
Added 'Cardinality' dialog to Reference menu - define list of cardinality types
Display {ordered} constraint on association role end when IsOrdered checked
Abstract operations now displayed in italics (UML convention)
First association constraint now displayed as boolean expression on association link
Active Class (and Active Objects) now supported. Set Class to IsActive on Property/Advanced page. All instances displayed with thick border
Property dialog now renamed to Tagged Values dialog and moved to reference menu
Role changeability now displayed on association role end where applicabel .. supports {addOnly} and {frozen}
Added optional compartment for Responsibilities on some elements. Activate using the "Set Feature Visibility" menu option on element context menu
Added optional compartment for Constraints on some elements. Activate using the "Set Feature Visibility" menu option on element context menu
Added optional compartment for Tags on some elements. Activate using the "Set Feature Visibility" menu option on element context menu
Attribute stereotypes now display
Added Local Option (Local Settings dialog - page 1) to toggle Open Maximized or remember last position
Added .frm, .bas and .ctl files as options for Visual Basic import
Fixed bug in EMF images that displayed Hyperlink icons in black
Fixed bug in .BMP generator that caused black stripe at bottom of image if view scrolled down
Fixed bug that caused crash under some circumstances when flipping between report and diagram view
Some fixes to VB code generator
