Author Topic: Missing ENUM and SET support for MySQL  (Read 3631 times)
helmut
  • Helmut Steinke ist hier
« on: January 07, 2005, 06:14:50 am »
in the release notes for build 740 I read that there was added support for ENUM and SET for MySQL databases. In the current build (744) I miss this feature.
Best regards
Helmut Steinke
hd
Re: Missing ENUM and SET support for MySQL
« Reply #1 on: January 09, 2005, 01:56:53 pm »
Once you have opened your model, go to Configuration | Database Datatypes.
Select Product Name: MySQL and add the ENUM and SET datatype here.
The vaues should be entered in the Intial: field of the attributes dialog.  Simply enter what is to appear in the brackets...
'M','F'
helmut
« Reply #2 on: January 10, 2005, 08:41:50 am »
Thank you,
it works, but there would be no possibility to specify an initial value of the enum?
Best regards
Helmut Steinke
hd
« Reply #3 on: January 10, 2005, 01:48:43 pm »
From MySQL Documention...
ENUM columns always have a default value. If you don't specify a default value, then it will be NULL for columns that can have NULL, otherwise the first enumeration value is used as the default value.
http://dev.mysql.com/doc/mysql/en/constraint_enum.html
Set the first enumeration value as the default.
