Author Topic: Search in tests  (Read 3387 times)
sargasso
Search in tests
« on: January 11, 2005, 03:51:53 pm »
Is there any way to search for a string in element tests?  :-/
As in , I know which usecase the test I'm looking for is in but the string - which could be in the name or the description -  is  a particular fare type.  The use case "book travel" has over 200 test cases  ....
tia
Bruce
Re: Search in tests
« Reply #1 on: January 12, 2005, 04:06:19 am »
Did you try to check the "Scenarios, Tags, etc." mark in the search mask?
sargasso
Re: Search in tests
« Reply #2 on: January 12, 2005, 01:49:22 pm »
had to export them all to excel, do the search and then go back to EA.
Bruce
mikewhit
  • Accessing ....
Re: Search in tests
« Reply #3 on: January 13, 2005, 01:47:05 am »
Sadly, Tests seem to be second-class citizens in EA - you can't search, copy, organise or link to them, use them in diagrams, or set up Relationship matrix entries with them ...
Although fundamentally this is because EA is geared to UML, some better means of mapping test coverage would be much appreciated !
