Author Topic: Defining my own Project Structure  (Read 5322 times)
jeshaw2
« on: January 12, 2005, 10:32:28 pm »
Created a new project based on EABase.  Tried to rearrange the view packages and was told I couldn't do that.  Tried to delete the Use Case package , so I could recreate it where I wanted it,  but got a scary message that this was a "system defined" package...did I really want to delete it?  Well I did, but I didn't understand the consequences of doing that, so I backed off and wrote this messge.
Are the consequences of deleting a "System defined" view too terrible to document?  And just what are the consequences?
How does one tailor the Project Structure (Like they did in the EAExample project)?
Martin Terreni
  • Sorry, I can't write
Re: Defining my own Project Structure
« Reply #1 on: January 13, 2005, 01:52:52 am »
no need to delete, you can just drug and drop.
any way it deleted fine for me and you can create new use case view.
Recursion definition:
jeshaw2
« Reply #2 on: January 13, 2005, 05:00:02 am »
Thanks for your response Martin, however, what build are you using?  I'm using 744.  Was your project based on the EABase model?  I'm getting different results from yours.
When I attempt to drag and drop I get the message:  "You cannot drag a view level package to another location in the tree".  The drag and drop failed to execute.
When I attempt to delete the view level package I get the message:  "Warning! You have asked to delete a system defined package.  This package cannot be recreated or restored."  Yes, I was able to delete the package, but what else did I loose?  I believe the EA Developers put that warning in there for a reason; what is it?  What are the implications of a package being "System Defined"?  I don't think my deletion of the view went just fine. :-/
How does one recreate a "System Defined" Use Case View?
« Last Edit: January 13, 2005, 05:04:12 am by jeshaw2 »
Martin Terreni
« Reply #3 on: January 13, 2005, 07:16:11 am »
you're ritgh about DnD.
about deleteing the view - you can reconstruct it, i beleave it just want be recoginzed as default use case view when importing from a project.
« Reply #4 on: January 13, 2005, 07:20:34 am »
Don't be afraid of those messages. The view levels are "special" packages which can't be moved around. I dop not make use of this structure and only one ore two view levels for a project. The important project information I store as packages in the first view which is named after the project.
This frightening message when deleting a project root is funny since deleting a single package can also not be undone (and thus the effect might be nearly the same). You can re-create a new view and start from scratch any time. Deleting the root just kills the package contents below.
jeshaw2
« Reply #5 on: January 13, 2005, 07:52:05 am »
OK, sounds like I can define my own project/documentation structure then.  Whew!
The fact that you loose child nodes in a heirarchy when the parant is deleted is obvious to most IT Techies.  What makes the messages scary is the use of the term "System Defined" which implys a lot of important  program logic and element behaviors.  Perhaps EA could rephrase the term?  :)
Thanks for hanging in there with me on this.
Hans
« Reply #6 on: January 13, 2005, 12:53:22 pm »
There's nothing to worry about: just delete what's in your way; btw it's the best you can do.
Hans
