Author Topic: Inline C++ methods  (Read 4630 times)
Martin Terreni
  • Sorry, I can't write
Inline C++ methods
« on: January 09, 2005, 02:16:31 am »
I've reversed engineered a class with inline methods.
after this a generated code from it, and correctly got inline methods again.
the problem is that I acn figure tou how to see that a method is inline in model or how to create in model and inline method.
any ideas?
Recursion definition:
Re: Inline C++ methods
« Reply #1 on: January 10, 2005, 12:10:35 am »
Maybe you could use a stereotype <<inline>>  ???
Martin Terreni
« Reply #2 on: January 10, 2005, 12:12:06 am »
it might work.
but I cant see when reversing.
« Reply #3 on: January 13, 2005, 02:35:26 pm »
The way the importer models it and the (default) code templates expect is with a tagged value "inline"="true".
There isn't a way to make tagged values show up on the diagram, but if you leave the tagged values dockable window open and select operations then you can select an operation to find out if it is inline or not.
Simon
Martin Terreni
« Reply #4 on: January 14, 2005, 12:33:01 am »
thanks
