Author Topic: Big class diagram, documentation and more question  (Read 10039 times)
wciesiel
Re: Big class diagram, documentation and more ques
« Reply #15 on: January 16, 2005, 05:38:52 am »
to do my job I have to, some times , reverse engineer old code to check it's architecture - then you might get to see things like that (or if your programing widows ;) )
That's what I thought :-) But even then those classes _should_ be divided into some packages, and you can create more than one diagram by using "add related objects" feat. Good luck with those 'lame' ;-) projects you have to analyze
Matt
    • Solutions Reality
« Reply #16 on: January 16, 2005, 07:42:32 am »
Hi there,
for really big diagrams, that all projects end up with at some stage, we copy the diagram using copy to clipboard and import it into Excel.  Not the perfect solution, but it works!
Matt
Martin Terreni
  • Sorry, I can't write
« Reply #17 on: January 16, 2005, 09:08:49 am »
interesting, I'll try it.
Recursion definition:
