Author Topic: Triggers & SQL Server 2000  (Read 2811 times)
stabiplan
« on: January 19, 2005, 02:06:45 am »
I found out I can add a trigger to a table. Doing so, I wonder howto:
- Set what kind of trigger it is (delete, update)
- Set the SQL for the trigger
Now only this is generated:
CREATE TRIGGER TR_ONDELETE
ON CUSTOMER
Feeding the script to SQL server query analyzer gives me:
'CREATE TRIGGER' must be the first statement in a query batch.
(I use one script for all tables)
Trying to be smart, I created a trigger in a SQL database and reverse engineered it into a model. Unfortunately the trigger does not show up in the model.
What can I expect from trigger modelling in EA?
Rob
hd
Re: Triggers & SQL Server 2000
« Reply #1 on: January 19, 2005, 03:22:29 pm »
Improvements in reverse engineering triggers is on our list of todo's.  ;D
At the moment, add the body of the trigger to its Notes field.
