Author Topic: How to populate an object in EA  (Read 3400 times)
Rosa
« on: January 27, 2005, 08:51:57 pm »
We have created our business model, logical model and classes. How do we create an instance of a class (the object) and populate it with real world values, so that we can have a real picture of contents and links? Thanks.
Bruno.Cossi
Re: How to populate an object in EA
« Reply #1 on: January 27, 2005, 09:00:12 pm »
1. How do you create an object, the instance of a class?
You can either simply drag the class from the Project View onto the diagram and when asked, select the option paste "as Instance of Element (Object)". If the question does not show up, just hold CTRL while dragging and dropping the class onto the diagram. Or you can simply place new Object onto the diagram, right click on it and select "Set Instance Classifier..." in the context menu, then select the Class your object should instantiate.
2. How do you populate the object with real world values?
Once you have created the object and specified the classifier, simply right-click on the object and select "Set Run State" from the context menu.
Hope this helps!
Bruno
Rosa
« Reply #2 on: January 27, 2005, 09:26:46 pm »
Thanks Bruno. It helped a lot!
Hope this helps!
Bruno
Bruno.Cossi
« Reply #3 on: January 27, 2005, 09:38:30 pm »
You're welcome!
