Author Topic: Image Library in XML format  (Read 2892 times)
airimie
« on: December 17, 2004, 05:35:42 am »
I am trying to import the image library found in the resources area on sparx website. I succesfully import the library, the problem is that if I do View Image (from appereance\Alternate image) it says something like "Error reading PNG file". IF I add the image myself with Add new, the image is imported correctly.
Also, as a feature request, I'd like to be able to export the images (from Export Reference Data), so I'll be able to use them in other projects. Also, some bulk Add it will be nice to be available in the Image Manager. Another improuvement of the image manager may be adding preview panel in the same dialog, and the dialog may be resizable. :)
EA 4.10.731
Thanks !
Alin.
shockyhan
Re: Image Library in XML format
« Reply #1 on: February 01, 2005, 01:14:31 am »
I have the same problem with EA 4.5 (Unicode, build 744).
johnr
« Reply #2 on: February 02, 2005, 01:25:27 pm »
This is a known bug that has been rectified in the new version of EA (Version 4.51) if you are a registered user you can test this beta by downloading it from http://www.sparxsystems.com.au/registered/reg_beta451.htm
