Author Topic: Data Model Diagram Configuration  (Read 2153 times)
tclevenger
« on: February 07, 2005, 01:34:57 pm »
Is there any way to turn off the default values for attributes in the data model diagram?  I'm documenting a legacy SQL schema which has:  Create Default DEF_Blank As ' ' on most columns.  These show up in the db diagram as:
<<column>> MyColumn: char(5) = Create DEF_Blank As ' '
I'd like to be able to remove the " = Create DEF_Blank..." part from the diagram.  Is this possible without actually removing the default value from the underlying schema?  Haven't found a way yet (can remove most other items from the diagram, but not this...)
Thanks!
Todd
Re: Data Model Diagram Configuration
« Reply #1 on: February 08, 2005, 04:16:23 am »
If no one else comes up with a better solution, try to remove these using the automation interface.
